Replacement dusk to dawn for light under porch overhang
Old 12-06-15, 02:04 PM
U
Seems like every few years I need to replace the photo sensor (won't turn off).
I would like to start using a dimmable LED, but the bulb flashes instead of going off during the day.
Is there an option where I can extend the photo eye with a wire?
Also, having trouble finding a replacement fixture with dusk to dawn. Most seem to be motion sensitive - not what I want.
Thanks in advance.
Old 12-06-15, 03:07 PM
Received 1,043 Votes on 967 Posts
If the photo sensor gets water in it.... it will stop working.
You'll need to use a three wire photo sensor if you want to use any bulb other than an incandescent. I would recommend using a dedicated photocell and not one in a fixture.
You'd need to explain that question better.
