Low voltage transformer / LED driver wiring
Old 01-06-16, 07:09 PM
G
Hello everyone,
I am trying to replace my old ceiling 12V MR16 transformers with LED-compatible ones, since the ones I have now start at 20w and cause leds to flicker. The problem I have is that because of the multiple lights wired in the ceiling, every fixture apart from one, has two wires going in the transformers, (L N, L N), and the Aurora transformers I have now do have two inputs, and one output for the bulb.
The problem is that every modern transformer has only one input (L N). What's the best way to get around this? Can I join the wires? LL and NN, squeeze both each in one input of the transformer? Do I need a connector of some sort? If so, what?
It's probably a very simple question for most, but I'm a novice, thanks for answering!
From what I saw, I think the wiring at the moment looks like in the picture below (the transformers are not shown)
Old 01-06-16, 07:15 PM
C
Received 174 Upvotes on 142 Posts
You would join the two black wires and a short piece of #12 black wire with a wire nut. Then join the two white wires and a short piece of black wire with another wire nut. The other ends of the short wires go to your transformer. This is called pig-tailing.
You can also use push in connectors instead of wire nuts.
Name:  push in connectors.jpg
Old 01-07-16, 04:53 PM
G
Thank you very much, I got a piece of wire and will try this tomorrow, I hope it works!
Old 01-07-16, 05:04 PM
C
I should have said join the two white wires and a short piece of *white* wire....black to black, white to white....Good luck!
Old 01-14-16, 03:01 AM
G
Thank you so much. It worked great! I opted for 3-way connectors, as wire nuts are not easy to find in the UK, I found these lever ones and they're amazing, and more stable than push-in ones.
Finally, I put LEDs in the kitchen! Thank you again! Name:  IMG-20160114-WA0000.jpg
