LEDs on when switch off
Old 01-07-16, 05:35 PM
K
Exclamation LEDs on when switch off
A little while ago, I purchased LED bulbs from Rona and a dimmer switch.
I put in the dimmer switch and replaced all the light bulbs in the room. The dimmer works, the LEDs dim correctly. My issue is, there's obviously a little bit of electricity leaking from the dimmer switch and causing the LED lights to have a glow to them when they're off (switch is turned off). I figure it's from the LED on the switch.
Is there a way to stop this? I'm afraid my LEDs are going to die sooner and they're also really annoying to sleep with.
Could I add a resistor between the positive line and the switch, or a capacitor?
Any help is appreciated. Thanks.
Old 01-07-16, 05:42 PM
Received 4,100 Upvotes on 3,682 Posts
Adding a resistor will make it worse.
You won't hurt the LED's but you'll need to change the dimmer to get them to go out completely.
Old 01-07-16, 05:52 PM
K
So, having them flicker whilst really dim is okay? They won't shorten the LED lifespan?
Old 01-07-16, 10:07 PM
I wouldn't think that would hurt them.
