Air switch for lighting
Old 01-08-16, 06:48 PM
I am getting ready to remodel my kitchen which includes a large island with a sink. I want to use Insinkerator style air switches on either side of the faucet to control the disposal and the overhead pendant lighting. For the pendents I was hoping to be able to get a compatible switch that would allow a low and high settings for the lights (press once for low, twice for high, three times for OFF). I would most likely use incandescents if that is most appropriate. Looking for help in the selection of a switch which could be controlled by the air switch. Here is a sample of the air switch I want to use.
Any thoughts would be appreciated.
Old 01-08-16, 07:25 PM
Handyone's Avatar
The ISE air switches are intended only for a device that is plugged into it, obviously mostly a disposer.
The pendants require house wiring.
Old 01-09-16, 06:00 AM
Handyone's Avatar
I'm posting a picture of the plunger and air module. Maybe someone knows of some type of plug-in transmitter that can be used.
Old 01-10-16, 05:22 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
It might be possible for someone to design an interface relay between the pendant light and an air switch, but it would probably require some extensive rewiring of the house wiring feeding the pendant light, possibly routing it under the sink through a relay. I am not terribly familiar with the air switches, but know enough about them to know that they were originally designed by Emerson Electric to control their hottub pump motors. It was a good idea that InSinkErator decided to adapt to their disposers.
Old 01-10-16, 06:31 PM
ray2047's Avatar
Expanding on Joe's information here is a type of air switch that you might be able to use. It is hardwired and could probably be mounted in a box. This one says maximum 240v/16a so it should work. http://www.aliexpress.com/item/Spa-P...00009.3.mVgXCL
