Landscape well light bulb
Old 01-12-16, 04:14 PM
K
Need to replace this bulb. Looks like a Halogen bulb. Is there a specific tool to go into the tread holes to get the casing up and open? Thanks
Old 01-12-16, 04:29 PM
Received 4,155 Upvotes on 3,731 Posts
Welcome to the forums.
Those three threaded locations appear to be a place to attach some type of lens. They aren't holding the bulb in place. You may have to pull bulb straight out to replace it.
It looks like a swivel mount on the two sides. You may need to use a screwdriver to remove the round frame from that mount. Slip the screwdriver in between the round part and the mount and twist.
Old 01-13-16, 04:53 AM
Geochurchi's Avatar
Received 162 Upvotes on 148 Posts
Agreed,tapped holes, there appears to be a small Phillips head screw there, loosen it an see if that cover lifts straight up, any mfg. info on the fixture?
Old 01-13-16, 05:21 PM
K
No there is no Mfg info. I will try the recommendations. Thanks for the help.
Old 01-14-16, 12:00 AM
In looking at the picture again..... it looks like the fixture is sitting in two tracks and just pulls straight up like the red arrows illustrate.
