Are my recessed light fixtures rated for insulation?
Old 01-29-16, 06:09 AM
C
Hello, this is the attic view of a VuLite V61C recessed light. There is no insulation covering it, presumably because the housing is not rated for it? Could I cover it with one of those Tenmat light covers or similar? Thanks!
Old 01-29-16, 07:05 AM
Handyone's Avatar
The actual model # is V6IC, not 1C. They are rated for direct insulation contact (IC).
You can cover the cans with insulation, but don't pack it in.
Old 01-31-16, 02:03 PM
C
Thank you for the response and clarification. Does it matter if I used faced or unfaced insulation here? Do I need to use mineral wool or is fiberglass okay?
