LED Dimmer Switch Troubleshooting
Old 03-01-16, 07:28 PM
N
Hi, first time poster here, hope to be on more as I tackle minor projects around my new (new to me, at least) house.
I recently upgraded all my light bulbs and fixtures to LED. I bought the products from HD, and the lights all work great, except for those on the dimmer switch. I have 6 lights in my basement tied to one dimmer switch, and it doesn't dim quite as much as my old lights did which is a small problem. But the bigger problem is that even if I click the light off, there is still a VERY faint glow from all 6, or sometimes, just one of the bulbs.
I checked both the items compatibilities with each other (specs and links below), so I'm not sure what I did wrong, could I have connected the wiring wrong? Could the lights or swi
If any pics of it would help answer, let me know.
Feit Model # BR30DM65 (light bulb)
http://www.usa.philips.com/consumerf...ilitySheet.pdf
Lutron Diva Model # DV-600PR-WH (dimmer switch)
http://www.feit.com/Dimmer_Compatibility
Old 03-01-16, 07:31 PM
G
mine do the same, they just don't dim as much as incandescent bulbs
Also my LEDs glow for 3-8 seconds after you click them off too
Old 03-01-16, 09:09 PM
Received 4,055 Upvotes on 3,638 Posts
Welcome to the forums.
As an electrician I run into these problems all the time. I have found the best dimmer to use is the Lutron Maestro. They make a CL model for CFL and LED use. The dimmer works very good on LED's. I haven't found anything that works well for CFL's. It's a few dollars more than most but to me it's worth it.
The biggest problem with most dimmers is that they rely heavily on bulb power consumption to dim properly. LED's present a light and unstable load.
The Maestro has a programmable ramp level that adjusts the dimmer to dim properly with most loads.
lutron/en-US/Products/MaestroDimmerSwitch/Overview.aspx
Old 03-02-16, 05:45 PM
N
Thanks, glad to hear it's not me! I'll get them exchanged this weekend and see what that changes.
Old 03-02-16, 07:19 PM
Handyone's Avatar
It's not you
You could spend a week reading compatibility charts and at the end it might say in small print "your experience may vary" or you will discover it on your own.
It is getting easier though compared to a few years ago to find full range dimming.
Old 03-05-16, 06:51 PM
N
Thanks PJmax for the advice on the Maestro switch, the dimming range is MUCH better for what I was hoping to get. I only replaced it tonight, but there is still 1 bulb glowing after I turn it off (at least not all 6 now). Given they are LED I know they aren't drawing that much power, do I need to be concerned if the lights never go out about wasting power or killing the bulb too fast? The Maestro switch does have the pull tab for "replace bulb" that turns them all the way off, if I get too crazy.
And for anyone wondering, below is the difference.
Diva dimmed all the way:
Maestro dimmed all the way:
Old 03-05-16, 07:50 PM
Did you find the programming instruction section where it tells you how to set the dimmer end stops?
Old 03-11-16, 11:18 AM
N
Yes, there was instructions that came with the switch. Where you hold a couple buttons at the same time and set the low setting until it is not flickering. Which for my case, was as low as I could put it.
