Strange 3 way switch/light combination
I have a simple light with just two connection terminals on it in my garage ceiling. It can be turned on/off with either of two switches. The wires to it are
two white wires to one terminal on the light, and one black and one red wire to the other terminal on the light.
Is this wired correctly? It works, but does not seem to match any of the wiring diagrams I have seen for a light operated by 3 way switches?
Any help, thanks.
Any help, thanks.
Received 124 Upvotes
hi walkerstoo –
I’m no electrician to say the least. I just try to follow this stuff to keep the old brain from decaying –lol. But I wonder if you actually have a second light or some other device connected to the 3-way switches. Maybe something that’s no longer is use or is hidden or something?
I’m just wondering if your setup isn’t like this:
3-Way Switch Wiring Diagram
If you turn the light on from one switch, can you turn it off then from the other? It sounds to me like you have two different circuits powering this light if there isn't another light somewhere like zoesdad mentioned.
strange 3 way wiring
It appears to be cable, the black and red wire appear to be two strand wire
the two white wires I am not sure, both come out of back of junction box were very close wired to light fixture.
What is two strand wire? Please post a picture. What you are saying doesn't seem to make sense. http://www.doityourself.com/forum/li...rt-images.html
