installing a 3 way switch with power to switch
Old 04-11-16, 01:22 PM
G
Hello,
I am trying to install a 3 way switch at an exsisting light with single switch. Power comes into the original switch to the light, but then passes the light on to another light and outlet. I have the new switch in place and it works, but now the light and outlet beyond the light only work when the switch is on. I missed something.... how do I get the power to go past the light on to the rest of the circuit?
Thanks in advance for your help.
Old 04-11-16, 01:32 PM
Received 3,891 Upvotes on 3,488 Posts
Welcome to the forums.
Unfortunately it's not as easy as just installing a three way switch. You need special wiring between three way switches.
Without adding additional wiring..... the single switch must remain.
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
How many wires are in the light box,did this work before you installed the 3 way switch?
Old 04-11-16, 01:39 PM
Received 1,262 Upvotes on 1,203 Posts
Why are you installing a three way switch? I don't just want to assume the answer is that you're going to add another switch in a second location.
Old 04-11-16, 01:42 PM
G
yes it worked before. and i understand that the traveler wire has to be installed along with the wiring to the 2nd - 3 way switch. Working on adding the additional switch currently. as typical hind sight is 20/20 i should have documented how the original switch was wired.
Old 04-11-16, 01:52 PM
G
Stickshift
You are correct adding an additional switch.
Old 04-11-16, 03:09 PM
G
ok, so both my switches are in place and the light is working from both switches. the circuit beyond the light works as long as the switch where the power comes in at is "on". the light itself can be off from the second switch but when i turn "off" the first switch the circuit beyond the light goes off as well. here is the diagram i used hmmmName:  wiring3l.jpg
Old 04-11-16, 04:15 PM
G
the light fixture is in between the switches though. it is a old house and pulling new cable is very tricky.
i think what you are saying is that i need to run an additional wire for the other load. in order for it not to be controlled by the switch. right?
Old 04-11-16, 04:38 PM
That is correct..... in addition to satisfying the new code which you aren't obligated to do since you aren't adding new wire between the switches.
Based on the diagram you posted.... you have hot but no neutral in the right hand box.
Old 04-11-16, 05:57 PM
ray2047's Avatar
I have deleted my last post. I missed you wanted to come off the light.
Old 04-11-16, 06:36 PM
Handyone's Avatar
I think you have this figured out with the help that was given. Just wanted to say this is one of the hardest things you will do in home wiring, so good job.
Old 04-11-16, 07:46 PM
ray2047's Avatar
Actually unless you have conduit you will need to run a cable and use both the white and black . You can't just run a wire.
Old 04-12-16, 10:31 AM
G
I guess, I really knew the answer the whole time. I was just hoping there was a "trick". Oh well why not add a little wall repair to my list of things to do. ( may or maynot have been how that hole got there) And thank you all for your answers.
Old 04-12-16, 12:05 PM
ray2047's Avatar
You normally can fish wire with out having to repair the wall. Why will you need to repair the wall?
Old 04-13-16, 11:36 AM
G
Originally from the switch (where the power is) they had a 3 wire bx cable. they were using one wire for the light and one for the load beyond the light with only one common. I pulled out the old and installed a new 3-12 w/bonded ground mc cable. That all worked fine and I did fish it through, but after that is when I realized in order to power the load beyond the light I would need an additional cable. The hole in the wall had to happen to add the additional cable since there was only one prior. I had to open up the wall to drill through the stud for the second cable. I am happy it is done, everything works and is actually updated and safer then before. Oh and the 2nd switch(which is why I started this) also required a small hole to get from the attic down. Today is patching day.
Old 04-13-16, 02:16 PM
ray2047's Avatar
Those darn pesky fire stops will get you every time. Good thing most houses don't have them. Thanks for letting us know how it worked out.
