Replacing 7 traditional flood lights with 7 LED (recessed) - all stop working ..
Hi - I want to upgrade my kitchen recessed lighting to LED lights to save money. there are 7 traditional flood lights installed today. I swapped the first 6 wit no issue, all worked well. As soon as I remove the 7th traditional flood light, all 6 of the already installed (and working fine) LED bulbs stop working. Even after I install the 7th LED bulb in, none will work. I replace the 7th bulb with back to the traditional flood light - all 7 work fine. WTH??? Why does the recessed lighting stop working when the 7th (last) LED bulb is installed?
These lights are on a dimmer.
Any thoughts would be greatly appreciated.
Received 38 Upvotes
Replace the dimmer with a regular switch and see if it works. Some dimmers don't like LEDs and some LEDs don't like dimmers.
I have two recessed fixtures and when I used a dimmable LED in one they both worked with the dimmer but when I replaced both incandescents with LEDs they would not go off, only dim to a certain level.
Some dimmers require a minimum number of watts to work. The seven LEDs may be two little but using an incandescent in the seventh light increases the watts to where it works.
I have done that before - left one incandescent lamp in the circuit to make an old dimmer work with LEDs. I have even made some non-dimmable LEDs work with the dimmer this way.
Other options include installing dimmable LEDs with a new dimmer that can take LEDs and CFLs.
