Florescent lights require a Smack before they turn on...
Old 04-23-16, 10:24 AM
K
So, I have some standard shop lights in my basement that are florescent tubes. On a couple of them, every so often when I turn on the lights, the light doesn't go on. I have to reach up and smack the end of the fixture and then the bulb will usually turn on.
I'm just wondering if this usually would signify a problem with the bulb or a problem with the fixture. I can go buy new fixtures but if it's just a sign the bulb might be going bad, that's cheaper to replace.
Thanks.
Old 04-23-16, 11:53 AM
ray2047's Avatar
It may be a sign they are not properly grounded.
Old 04-23-16, 12:28 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Could be a loose connection in the socket,swap the lamps out with one of the other fixtures and see if the problem follows,doubt it's the lamps though.
Old 05-01-16, 08:49 PM
Things to check:
- If these are cord and plug connected, is the plug a 3-wire plug? Rapid-start lamps need that ground to start. You touching the fixture are providing a partial ground.
- If the reflector has been removed from the lamp, put it back. The grounded reflector aids the starting process (the reason for the ground above).
- If the lamps have preheat starters, replace the starters.
- Check for loose connections.
