Advice needed
Old 05-01-16, 02:10 PM
N
Advice needed
Member is in the UK.
I have put new ceiling lights up today in the front and back rooms. Faced with nine wires in the ceiling. three red, three black (one with a red sheath) and three earth. I googled and found that the three red should be bundled and seperated off together. I fixed the earths to the light fitting, the two black to the neutral fitting and the black with red sheath to the live fitting.
Electric back on and all worked fine.
Until tonight when i took my little one up tot bed. I noticed the bottom of the stairs light did not work? Turns out the lights do work but only if i turn the living room light on and then both lights work at half power (dimmed lights) I can turn the living room light off using the passage switch! What on earth have i done wrong? See vid showing current set up.https://youtu.be/pp_s0iLvGbA
Old 05-01-16, 02:32 PM
ray2047's Avatar
This is primarily a North American forum. Your wiring colors in the UK are different from ours and sometimes your wiring conventions are different. I'm not sure anyone here can give you much help.
Did you do any wiring in the switch boxes? Is this a 2-way circuit?
Old 05-01-16, 03:10 PM
N
Ah apologies. I didn't realise it was not a UK site. Will remove post. Thanks.
Old 05-01-16, 04:52 PM
ray2047's Avatar
You can't remove it and I won't just in case someone with an answer sees it.
