bath fan (4 function) wiring question
Old 05-16-16, 05:08 AM
C
Trying to wire a four function bath fan (vent,heat,light, night light) to two switches (three toggle and single switch) which will be side by side. their is 12/2 romex power running to the switches and two 12/3 wires running between switches and the bath fan. The bath fan is a Panasonic whispertone (FV-11 vhl).
The attached drawing is one option I tried and failed. I apologize for the drawing in advance. This is my last resort, my wife has lost patience with me. Thank you
Old 05-16-16, 06:59 AM
pcboss's Avatar
Received 87 Votes on 74 Posts
Your diagram looks correct. What is the issue you are having? Does any of it work?
Old 05-16-16, 07:24 AM
C
Switches seem to work starting/stopping power to unit when tracing with detector. Unfortunately, none of the functions work on the unit For instance, I will flip the main light switch and test where the bulb would go and it would test hot, but also the night light would test hot. Is something screwed up with my neutrals? I do not understand how power is getting to the unit, but not running anything. I also tried isolating the wiring to just the main light and that did nothing. Getting frustrated.
Old 05-16-16, 07:53 AM
Received 1,112 Votes on 1,032 Posts
You said 2) 12-3 cables between switches and fan yet you are showing a 12-2 and a 12-3.
Old 05-16-16, 07:58 AM
C
you are correct, I miss labeled the drawing. one wire is not used on the second 12/3 essentially making it a 12/2
Old 05-16-16, 08:28 AM
pcboss's Avatar
It sounds like you are using a non-contact voltage detector. They are prone to false positives. Install the bulbs and fan motor and then test.
