3-way Z-wave switch wiring problem
Old 05-21-16, 12:31 PM
K
Separated from: http://www.doityourself.com/forum/li...er-remote.html
so i am having issues trying to get the paired remote working as well. here is my setup:
bottom of stairwell i have the following connections, and this is where i assume i should put my main dimmer
1- black hot wire
2 - orange load wire to lights
3 - purple traveler 1
4 - purple traveler 2
5 - neutrals
top of stairwell i have:
1- red wire which is hot (this red wire is nutted together with the black hot wire at bottom of stairs, and that is where its getting power it seems, as when i disconnect them at the bottom, it no longer is hot)
2 - purple traveler 1 (i have tagged them)
3 - purple traveler 2
4 - neutral wire
The top stairwell box also has other wires that control a different switch in the kitchen. Im also trying to get this set up with the same switches and running into similar issues, but 1 thing at a time. this may or may not be relevant, but the other wires in the top of stairwell box are like this: 2 purple travelers, 2 reds, and 2 neutrals. the reds are nutted together and so are the whites... i think these are unrelated though to the 2 switches in question.
for the main dimmer, where do i connect line, load and travellers. it seems like line=black, load=red, ylw/red=trav 2, but i dont have a place for trav1?
for the companion, it seems like the instructions tell me to nut together trav1 and hot, and just connect the neutral and trav 2 to the switch.
I had an electrician over doing some other work and asked him but he didnt know, and said hes never seen a 3 way switch where a traveler and hot are nutted together on one end.
Thanks in Advance!
Old 05-21-16, 12:34 PM
ray2047's Avatar
Moved to its own thread to prevent confusion.
Old 05-21-16, 12:38 PM
Received 3,887 Upvotes on 3,484 Posts
I specialize in electronic dimmers. I actually have other electricians that call me to help them.
You have hot at both switches.
The load is at the lower switch.
Since you have a conduit system you could probably put the master at either end.
Can you post the make and model of the main and slave unit you are using. They are not all wired the same.
Old 05-21-16, 01:03 PM
K
thanks! the main is the leviton dzmx1-1l and the slave is the leviton vp00r-1lz
Old 05-22-16, 10:55 AM
K
do i need a different slave, teh vp00r-10z?
Old 05-22-16, 11:57 AM
Did you mean DZMX1-1LZ ? You will be able to use the VP00r-1lz (LED) slave.
Bottom of stairs - main dimmer location
1- black hot wire
2 - orange wire - load
5 - neutrals
Top of stairs - slave location
1- red wire (hot wire)
4 - neutral wire
Diagram to follow shortly.
Old 05-22-16, 05:33 PM
This is your finished diagram. The connections are very straight forward.
You will not use traveler 2.... just cap it off at both ends.
Old 05-23-16, 11:41 AM
K
thanks, will try it out tonight and hopefully it works
Old 05-23-16, 12:00 PM
K
quick question: i dont have LEDs, is this still the setup i would use, as the instructions have different wiring for no-LEDs
thx
Old 05-23-16, 12:11 PM
You specified the slave with the LED's on it. Isn't that the one you are using ? VP00r-1lz
We didn't discuss the load/lights at all.
Old 05-23-16, 12:37 PM
K
ah! yes that is the slave i have. i was confused by what was meant by "no-leds"/"with LEDS".... i thought that was referring to they type of lights (load), not the switch!
Old 05-26-16, 05:06 PM
K
It Works!! thanks so much
Old 05-26-16, 05:09 PM
You're welcome..... Good job.
