Removing recessed lighting can
Old 05-28-16, 07:40 AM
Hi, could someone please advise on how to remove a recessed lighting canister pictured here? I am trying to get it down to re-wire for an led replacement but I cannot get the canister down, no clips or screws seen on the inside of the can, I cannot figure out how to get the can out. Any suggestions please? Thank you. Name:  20160528_071252_resized.jpg
Size:  13.9 KBName:  20160528_071259_resized.jpg
Old 05-28-16, 08:41 AM
Received 4,055 Upvotes on 3,638 Posts
Welcome to the forums.
I have exploded views of that recessed lighting fixture but I cannot find them.
The can is held in with clips at the three locations that are visible. Hold on to the trim, pull it straight down while gently turning it. It will come down.... it's only a pressure fit.
Old 05-28-16, 09:15 PM
Thank you Pj, it worked! I just needed to know if it could be removed, and kept pulling and it finally came out. Thanks.
