Electronic speed control for whole house fan
Old 05-29-16, 07:35 PM
D
Can I use a Broan 6amp 120v speed control on a 1/3hp 1 phase 5.7amp motor, to adjust speed successfully? There is also a timer in this circuit. First time ever on any forum.
Old 05-29-16, 08:52 PM
Received 4,148 Upvotes on 3,725 Posts
Welcome to the forums on your first time.
Even if you were able to use a speed controller on your fan.... 5.7A on a 6A device will run hot.
I haven't seen a speed controller that work well with that type of motor.
Usually a two speed motor is used as many motors will run too hot when the voltage is reduced to them.
Old 05-30-16, 12:07 PM
E
Received 5 Upvotes on 5 Posts
Searching for Broan 6amp 120v speed control brings up the page but not a lot of details, still the size and price make it seem unlikely to work.
You need something like this: https://www.anaconsystems.com/text/opti_e1.html
Old 05-31-16, 07:34 PM
D
Electronic speed control for whole house fan.
Thanks for the replys, my daughter's fan had a variable "dimmer style" control originally and finally bought the farm, so we replaced it with a 6 amp unit that lasted a year, so I did not want to go down this path again without help. Guess I should look for different motor if she insists on the variable speed. Thanks again for your time and input.
