Installing new ceiling fan (wiring help needed)
Old 06-16-16, 12:22 PM
I installed a fan that is not compatible with a dimmer switch. I need to replace the right switch in the attached image. As it shows, each switch has two red wires and one black. The black from each switch are all wired together with the two black wires from the box. The red wires are then connected to seperate blue wires. I am thinking the black is hot (common) and the two red from each switch are travelers but could use some help. Thanks in advance.Name:  image.jpg
Old 06-16-16, 12:28 PM
C
Received 174 Upvotes on 142 Posts
So there is a second, standard (non-dimmer) switch that also controls this circuit? If so then yes, the two blues are travelers. On the replacement 3-way switch you would wire the black wire to the black terminal on the new switch and the two blues to either of the other two terminals.
Old 06-16-16, 12:32 PM
That is exactly the case... Do I keep all the black wires together?
Old 06-16-16, 02:35 PM
I just wired a new switch and in order to work the fan, it has to be in the off position.... Any help there?
Old 06-16-16, 03:16 PM
ray2047's Avatar
Is this a different fan? .
Old 06-16-16, 03:43 PM
No same one. Switch works fine just has to be installed with the top down
Old 06-16-16, 04:17 PM
ray2047's Avatar
Switch do not have a top or bottom. Does the switch turn the fan on and off? Is it marked with an off position? if so is it off in the off position?
Are these 3-way switches? That is are there another set of switches in a different location that also control the fan?
