How to open this bathroom exhaust fan to replace light bulb
Old 07-03-16, 07:31 PM
T
Anyone help me to open this exhaust fan to change light bulb. It can't pull down, turn, no screw.
Old 07-03-16, 08:13 PM
Received 4,049 Upvotes on 3,632 Posts
Since it's a two piece cover.... I'd imagine the plastic lens needs to be removed first.
The lens may unsnap or turn slightly to separate from metal canopy.
Old 07-03-16, 08:49 PM
T
Thanks Peter, the Lens unable turn or pull down, it attach solid. The base are caulked to ceiling.
Old 07-03-16, 09:12 PM
If you can't get the lens to separate from the canopy then it must be a pull-down canopy. You'll have to carefully use a knife to score between the canopy and the caulk.
