Wiring question for ceiling fan
Old 07-04-16, 07:05 PM
I am in the process of trying to install a ceiling fan in my son's room and need some advice.
The fan has a wall control and the instructions state "Warning: Hook up in 'series only' Do not connect the hot and neutral wires of electric circuit to the wall control."
The box on the wall just has one black and one white wire, which I assume are the hot and neutral wires. But, the fan is replacing a light that had a dimmer, so why can't I just wire the wall control for the fan the same way as the dimmer?
Thanks in advance for any help.
Sean
Old 07-04-16, 07:14 PM
Received 4,056 Upvotes on 3,639 Posts
Welcome to the forums.
You have what's called a switchloop. The hot is brought down on the white wire and is returned back up on the black wire. In the following diagram.... your dimmer replaces the switch and you have a fan in place of the light.
ray2047's Avatar
Wrong assumption. It has a white wire that by code was supposed to be recolored black or red or any color but white, gray or green to indicate it is a hot not a neutral. However remarking is often not done.
