Dimmer for screen porch string lights
Old 07-09-16, 10:19 AM
D
Electrically challenged so bear with me...
Have a screen porch with a single string of lights (15 incandescent bulbs @ 11 watts each) that plugs into an GFCI outlet attached to a porch post.
We really like the string lights but would like to be able to dim them. I've seen dimmers that plug into the outlet which you then plug in the lights but none rated for outdoor use. Any ideas other than wiring a dimmer switch and buying new hardwired lights? Below is a pic of current setup. I appreciate the help!
Old 07-09-16, 11:10 AM
ray2047's Avatar
They do make a special receptacle and plug which allow a code acceptable way to dim a receptacle. Lutron Electronics Introduces Dimmable Receptacle | Lighting Controls Association
Old 07-09-16, 11:16 AM
Received 4,046 Upvotes on 3,630 Posts
I would install another weather proof box above your receptacle. I'd install a dimmer in it and use an in-use cover to secure it from the weather. Then at the top.... install a single receptacle. If you kept the box up high enough you wouldn't need a WP cover on it.
The little picture below is just an illustration of an in-use cover. Your application would put the dimmer there.
Size:  3.5 KB Name:  IMG_6286.jpg
