Adding motion detector to a lamp post
Old 07-10-16, 10:24 AM
Hello All,
Newbie here. First posting. I want to add a motion sensor to my lamp post, so it will come on at night when we pull into the driveway.
The lamp post has a dead photo cell for dusk to dawn operation which I removed.
I have two (2) questions, please:
(1) how to wire - the lamp post has three (3) wires, one white, one black, one copper. The motion detector unit has four (4) wires, one white, one black, one copper and one red. From what I read online I believe the white goes to the white, the black to the black, the copper to the copper, and, here's the 1st question, I believe the red goes to the black, along with the other black - is this correct?!
(2) the hole in the lamp post which housed the dusk to dawn photocell is much bigger than the hole I need to mount the motion sensor - any thoughts on how I can make this work would be appreciated!
Photos:
So sorry, I couldn't get the photos to sort properly;
#1: the motion sensor engulfed by the photocell hole
#2: the hole from the old photocell
#3: the 3 wires coming out of the lamp post
#4 my thoughts on how this is supposed to be wired ie the red gets attached to the blacks, right?
Thank you.
meallthumbs
Old 07-10-16, 11:52 AM
ray2047's Avatar
Cut the old photocell off leaving just the mounting plate. Use the nuts to secure the new sensor to the old mounting plate.
Old 07-10-16, 05:37 PM
Thanks Ray! All done & working fine.
Retrofitting the dead photocell took a little extra effort. The motion sensor did not fit neatly into the old hole of the photocell - I needed to expand the hole. It's not pretty but it works. Next I'll need to run some kind of sealant around the entire mount to keep out the elements.
Thanks again. I think I'm gonna like it here!
Old 07-10-16, 05:52 PM
ray2047's Avatar
Welcome aboard and thanks for letting us know the outcome.
