Changing lighting wiring
Old 07-14-16, 05:48 AM
Hello,
In my kitchen, there are three lightswitches. On one side there is a single switch, which controls the kitchen lights. On the opposite side, by the back door, there is a double-switch, on which, one switch also controls the kitchen lights, and the other controls the outside light.
I would like to change it so there is only two switches: one for the kitchen lights (where the existing single switch is) and one for the outside light - replacing the double-switch with a single.
Here is how it is currently wired:
The single switch has a black wire with a grey sleeve doing into the top, a grey wire going into the bottom-left (when looking at the back of the plate) and a brown wire going into the bottom-right.
On double switch, the switch that controls the kitchen lights (i.e. the switch I want to remove) has a black wire going into the top, a grey and a brown wire going into the bottom-left, two brown wires going into the bottom-right, and a brown wire connecting the bottom-right to the top of the other switch (so there is a total of three wires in the bottom-right). The switch that controls the garden light (i.e. the switch I want to keep) has a brown wire with a grey sleeve going into the borrom-left and the wire connecting the two going into the top.
What do I need to do?
Thanks in advance.
Old 07-14-16, 08:34 AM
pcboss's Avatar
Received 196 Upvotes on 172 Posts
Depending on how the three way switch is wired you may not be able to remove it. Why do you want to remove the three way?
Old 07-14-16, 09:31 AM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
I have never seen switches or cable like that. Is this in a mobile home?
Andy
Old 07-14-16, 11:23 AM
Nope, just a regular house.
Old 07-14-16, 11:27 AM
pcboss's Avatar
Where are you located? .
Old 07-14-16, 11:31 AM
The UK
(Apparently this post is too short, so just padding it out...)
Old 07-14-16, 02:29 PM
ray2047's Avatar
This is primarily a North American forum as you can guess at the questioning about devices. We can give general advice about what you call a 2-way and we call a 3-way but it may or may not be applicable to UK wiring which uses a different wire color scheme and somewhat different devices. We can comment on if what you want to do is a code violation. Here code depending on a number of factors and local code may require a switch at both doors.
