Is there something wrong with this dimmer switch wiring?
Old 07-15-16, 06:01 AM
richpodraza's Avatar
Received 2 Upvotes on 2 Posts
In my new home I noticed the dining room lights with a dimmer switch installed will often make noise or flicker. I think the problem is this green ground wire is not attached to anything but I am not totally sure about that. The other 3 connections seems good to me. I unscrewed the nuts and made sure the wires had good contact and then screwed them on tight again. But the problem still exists. Any ideas?
Size:  16.5 KBName:  20160715_082854.jpg
Old 07-15-16, 07:28 AM
ray2047's Avatar
Ground is safety not function. Use of LEDs or CFLs can cause those symptoms.
Old 07-15-16, 01:34 PM
pcboss's Avatar
Received 195 Upvotes on 171 Posts
It could be the filaments in the bulbs buzzing.
