Can you use "índoor only" light electronics outside in a weatherproof box?
Old 08-01-16, 05:22 AM
E
Received 5 Upvotes on 5 Posts
For example a Phillips primavision mini. It would go in a ip64 Alum box.
Is there a rule of thump for how far the control gear can be from the bulb?
Old 08-01-16, 10:00 AM
Received 3,897 Upvotes on 3,494 Posts
As far as I know.... an IP64 box is not considered water proof like an NEMA 3 enclosure.
You want to remote a ballast. Is the fixture weatherproof ??
Old 08-01-16, 10:30 AM
E
Sorry it's ip65. It's sold as weather proof but not immersion proof.
The fixture is weatherproof. The ballast is not. None of the small ones are. Edit: that I've found, I've asked in a few stores and the smallest outdoor ballasts are 250w
I notice that sometimes in stadiums or parking lots they have all the ballasts on the central post with the lights distributed along a rail. Is there a limit to how far the ballast can be from the bulb?
Old 08-01-16, 10:45 AM
F
I worked in one facility that had high-bay mercury vapor lights where the ballasts were mounted on a building column at floor level for service. Some of the wire runs probably exceeded fifty feet.
Old 08-01-16, 12:49 PM
E
Thanks Furd,
Do you know if the used regular cables or do they need special ones. Normal low voltage wires say 750v but I think the striking current for the discharge lights is several kv.
Old 08-01-16, 05:13 PM
F
All the wiring was in metallic conduit and I never had any reason or inclination to remove any covers to inspect the wiring. I assume it was just standard THHN/THWN insulated copper. I could be wrong.
Old 08-01-16, 09:48 PM
You didn't say what lamps or exact ballasts you're using but I doubt the voltage is as high as you think. Many ballasts have open circuit voltage listed on them.
Most ballasts I've remoted used standard THHN wiring. That includes 1000w metal halide fixtures.
Old 08-01-16, 10:48 PM
E
These are the bulbs MASTERColour CDM-T 35W/830 G12 1CT/12 MASTERColour CDM-T - Philips Lighting
It says ignition peak voltage (max) 5000, but I'm not completely clear on how a ballast works so it's all Greek to me. I'll just use appropriately sized copper
