Lomanco attic fan not working
Old 08-18-16, 02:56 PM
D
Received 3 Upvotes on 3 Posts
I have a Lomanco attic fan, model# F0510B2944 that stopped working about a week ago. house is 16 years old. I replaced motor/blade assembly about 14-15 years ago (no charge by manufacturer). Not sure if it's thermostat or motor, and don't know how to test. I could just replace both (or purchase both and replace 1 at a time) but would like to do it correctly (my luck it is a faulty/loose wire!!) About $68 for motor and $28 for thermostat from manufacturer, exact replacement. Thanks!
Old 08-18-16, 03:45 PM
ray2047's Avatar
Bypass the thermostat by connecting the two wires to it together with a wire nut. Turn the breaker back on and see if it runs.
Old 09-03-16, 10:56 AM
D
Going to troubleshoot fan & thermostat today, being both are about 16 years old, does it make sense to replace thermostat even if working fine? If fan is ok, I may just order replacement to keep on hand. Thoughts?
Old 09-04-16, 03:00 PM
D
ok, disconnected fan & bypassed thermostat. Nothing. Ordered a new motor from manufacturer, not going to replace thermostat unless I have issues when installing new motor.
Any way to test if thermostat is working while waiting for new motor to arrive?
Also had a tough time getting the old motor/fan assembly out passed the 3 angle brackets. Thinking I need to insert new motor and fan blade separately into housing so I don't bend the blades, does this sound right?
Old 09-04-16, 03:23 PM
Received 3,885 Upvotes on 3,482 Posts
You should have 120vac at the fan motor if the the thermostat is working.
You could also check for 120vac inside the thermostat junction box.
Some of those fans require the motor and blades to be installed separately.
