Recessed lighting trim removal
Old 09-01-16, 07:04 AM
D
Hello, This is my first post and I hope I can find some help here.
I have a can light over my shower. Recently the cover and the trim have melted enough so that I cant put the cover back on. Also, the trim has started to droop leaving a gap between the trim edge and the ceiling. What I want to do is remove the Trim and replace it with a wet location LED retrofit. The issue I am having is that when I pull the trim down there are no clips on the side to release it from the housing. I then used my fingers and poked them into the hole around the socket to look for a spring and found nothing there. When I pull down on the trim the socket moves with it. Any ideas on how to remove the trim? Could it be that the trim and housing are one piece?
Old 09-01-16, 07:39 AM
C
Received 109 Upvotes on 88 Posts
Sliding those spring clips near the socket toward the socket should release the trim from the socket.
Old 09-01-16, 08:49 AM
Received 3,423 Upvotes on 3,069 Posts
The trim and housing are not one part. Where I put the red circles should be three clips on the backside. They may be bent and stuck.
Old 09-01-16, 11:50 AM
D
How would you suggest loosening these clips?
Old 09-02-16, 05:50 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Have you tried twisting it while pulling down on the trim,any mfg. info on the fixture?
Old 09-02-16, 06:34 PM
Exactly like Geo stated..... twist and pull down.
