new bulb blows fuse instantly in one ceiling fixture. Fixable?
Old 10-01-16, 03:02 PM
im guessing its shorting up there. the fixture a few feet from it works. is this a loose wire or something i can diagnose? thanks
Old 10-01-16, 03:26 PM
Tolyn Ironhand's Avatar
Received 674 Upvotes on 572 Posts
Maybe. Depends on your troubleshooting skills.
You likely have a wire connected to the wrong splice. Does it pop the breaker without a bulb installed?
Old 10-02-16, 05:48 PM
Thanks! im up for a challenge
It does not pop the breaker. It is one of 3 ceiling fixtures and im using the other 2.
It used to work, and then suddenly the bulb in the fixture stopped working, so i put in a new bulb and that one immediately fused. that was a year ago and havent tried since.
Old 10-02-16, 05:57 PM
B
Received 47 Upvotes on 43 Posts
Try one of the known good bulbs. What type of bulb are you using, incandescent, LED, other?
Bud
Old 10-02-16, 06:07 PM
Take a multimeter (set for 250 volts) and measure the voltage at the socket. Or take the fixture down and measure the voltage where the fixture wires connect to the house wires. You should get 120 volts.
Old 10-02-16, 06:30 PM
ok i just put in a 5W led bulb (tripped on a 20ish W cfl) 10 minute ago and its working. its a recessed ceiling fixure: https://i.imgur.com/VvvmWCq.jpg can it be removed?
Old 10-02-16, 10:09 PM
B
My guess is the cfl that tripped the breaker has a problem. The difference in load between a 5W LED and a 20ish (?) cfl is minimal. Do you know what other lights or other loads are on that circuit? What size is breaker that is tripping?
Bud
Old 10-03-16, 03:45 PM
thing is Bud, it used to work on a CFL that was like 15-20W then it stopped working after like a year. I replaced with another 15-20W cfl which immediately stopped working. That was a year ago. Yesterday I put in a 5w led and it still works now.
the kitchen has 4 light fixtures like the picture below, the other 3 have 15W cfl bulbs. The breaker never tripped that i remember.
Old 10-03-16, 04:46 PM
You keep using words like "tripped" or "blows fuse". Exactly what is blowing or tripping?
Old 10-03-16, 06:37 PM
O
Hello:I am new to this site and am registered and checked in but I don't know how to post a question. Sorry if I am busting in on someone else post.
Old 10-03-16, 07:08 PM
ray2047's Avatar
Welcome to the forums. Go to the entry page for the forum that best fits your topic.
Old 10-07-16, 08:49 AM
well the bulb is probably what blew a fuse internally. no breakers tripped. the fixture is also fine, apparently.
