how to test cfl four pin bulbs?
Our bathroom fan uses four-pin CFL bulbs just like shown here:
https://www.amazon.com/FDS18E35-18W-...s=FDS18E35%2F4
One burned out so I ordered up some replacements but a generic brand version instead of the Panasonic. I got a three-pack but none of them worked after I plugged them in. I have a multimeter; on which two pf the four pins should I touch the two probes to, and what setting do I set the multimeter so I can check for continuity to see if these new bulbs are no good or what. thanks
There are no filaments in those lamps which means there is nothing to check with a meter.
Did you try swapping them where there is a working one ?
I figured it out. I had been leaving the light switch on the ON position while changing out the lamps. Apparently when you do that with these type of lamps, the lamps won't turn on. You have to make sure the light switch is switched OFF, then replace the lamps, then switch the switch to ON.
All my new lamps are fine, as is the one that was previously working.
Actually I showed my wife what was going on. She said "I think you have to have the switch off when you change it". I said "naw that wouldn't make any difference". So she said let's try it anyway. So we did. Then it all worked.
Think I'll start listening to her more often.
