How do I know if kitchen recessed lighting is low voltage?
Old 10-23-16, 09:02 AM
Recently moved into a house with recessed kitchen lighting. It has 6 cans, 3 are controlled by one dimmer switch and 3 by another. They use 65W incandescent flood bulbs. The lights have been flickering lately and it seems to be the dimmer so I want to replace them. They are a no-name brand. Have been reading about buying a dimmer - how do I know if the lights are low voltage or line? Thank you.
Old 10-23-16, 10:54 AM
C
Received 166 Upvotes on 134 Posts
Most likely line voltage. To confirm, check the bulbs; they will usually have voltage printed on them.
Old 10-23-16, 12:49 PM
Good point - the bulbs are standard incandescent so line voltage. Thank you.
Old 10-23-16, 08:21 PM
Tolyn Ironhand's Avatar
Received 864 Upvotes on 727 Posts
There are low voltage incandescent bulbs available. However, I do suspect they are line voltage. To be sure look at the bulb. It will say either 120-130 volt (line voltage) or 12 volts (low voltage)
