Surface Mount switch
Old 10-31-16, 01:18 AM
C
I recently was given a Leviton Surface Mount switch. Its labelled as a toggle basically for wall mounting. Apparently they used to be very common and now harder to find. My questions would be: What are the common uses for this switch? I wanted to put it on wall by the door to control a 3 way lamp. I have the appropiate wire for lamp and polarized plug replacement. The Leviton switch is rated 5a-250v -10a-125v.
I tried to do some research but got confused as most switches i have are of course 15a and I've just never seen this before. Can I use it still? Thanks in advance!
Old 10-31-16, 01:59 AM
ray2047's Avatar
The ones I am familiar with were used with lamp cord stapled to the wall or baseboard. Not a method that would meet modern code. Today you would use surface raceway, surface mount boxes, THHN wire, and standard devices. Look up Wiremold on the internet for more information.
Old 11-01-16, 02:00 AM
C
Well i know you can buy inline cord switches and they say on packages for lamps or small appliances. Most of the ones i saw were rated 3a or 6a. Since I am only using the switch for a lamp I think I should be fine. It must of been seeing the wierd amp on switch which made me wonder is all.
