Outside flood light / can't find a mounting box for my siding
Old 11-14-16, 06:57 AM
SBI
SBI is offline
Greetings all,
I want to install a flood light and our siding (new; one year old) has 3/4" overlay and I don't see a mounting block anywhere that fits 3/4" overlay. Largest overlay I can find is for 5/8".
I prefer not to mess with the siding, remove it, cut it, etc, for an "inside" block.
Any solution other than using the 5/8" and caulk the gaps?
Thank you.
Old 11-14-16, 07:16 AM
Received 1,113 Votes on 1,033 Posts
If you install the box horizontally.... it may not need a block.
Old 11-14-16, 09:27 AM
SBI
SBI is offline
There is no box, just a Romex coming in to the spot and a block that needs to be on the siding and the flood light itself attached to the block.
Old 11-14-16, 09:36 AM
The block still requires cutting a box into the siding.
Maybe you need to consider a surface weatherproof box.
Old 11-14-16, 02:14 PM
Geochurchi's Avatar
Received 73 Votes on 69 Posts
I know you don't want to mess with the siding but it's not that bad,use an oscillating cutting tool to cut it.check Arlington's web site.
Old 11-14-16, 02:27 PM
Received 77 Votes on 72 Posts
What type siding is it?
With a picture we could see what your seeing.
That we could see if it's possible to attach it to the fachia, or soffit instead.
Old 11-14-16, 02:44 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
Arlington has quite a selection of siding mount boxes, including ones for retrofit.
www.aifittings.com
Old 11-15-16, 09:31 AM
SBI
SBI is offline
Old 11-15-16, 09:36 AM
SBI
SBI is offline
Arlington | Quality Electrical Products and Fittings
I actually looked on their web side and didn't see anything with 3/4" panel projection.
Old 11-15-16, 10:33 AM
XSleeper's Avatar
Received 675 Votes on 624 Posts
If its overlay, get one for 5/8" siding and notch the back out a little more. They are vinyl, its not that big of a deal to notch or grind it for a custom fit. 1/8" is close enough to caulk anyway.
Old 11-15-16, 04:23 PM
Not want to do the extra work all you want but the right way would be to use a real siding block.
Electrical Blocks (UL Listed)
Old 11-15-16, 07:02 PM
G
Buy a box like THIS
Turn it sideways, horizontal, and bring the wire through the back of the box.
Mount your spot light to a cover like THIS
Another alternative would be to use the same box with a flat blank cover
and use an LED surface mount light light THIS
You could run 14/3 SJO cord from the box to the light and use cord grips instead of connectors.
Old 11-15-16, 07:40 PM
I'm old school. I don't like the looks of the blocks on a house with siding like that.
You do not have to use a mounting block for it to be done the "right way".
I still cut boxes into wood siding. Usually horizontally oriented.
I use a router and an oscillating saw although the saw is all you really need.
Old 11-16-16, 06:48 AM
Big difference between vinyl and wooden siding.
Vinyl has to have room to expand and contract or it will buckle.
Just trying to caulk around the block will just crack over time.
Why would you want to use something made of wood instead of something that never needs to be painted?
