Connecting ballast which wires to where
Old 11-16-16, 05:41 AM
E
Received 5 Upvotes on 5 Posts
So I have to connect this electronic ballast to this 4 pin socket
<img src="https://lh3.googleusercontent.com/-TabrR1JQiwA/WCxSVyK1SUI/AAAAAAAAHD8/OthCJSkCDe0/s1024-no/IMG_3985.JPG" width="1024" height="768"/>
There are two pairs of wires coming out of the "lamp side" of the ballast does each pair go to one side of the base or do need to be crossed with one from each pair to each side:
The diagram on the ballad shows that each pair would go to one side of a tube but not sure how that equates to the compact base
Old 11-16-16, 06:26 AM
ray2047's Avatar
Please post a clear picture of the diagram.
Old 11-16-16, 07:36 AM
E
I don't have it with me to take a pic but this what the diagram looks like
http://spanish.yorongar.com/photo/yo...2904_67673.jpg
Old 11-16-16, 10:44 AM
Received 3,891 Upvotes on 3,488 Posts
Those 4 pin bulbs are two separate bulbs in one. You can see which two pins go to each half.
Size:  19.1 KBName:  tube.jpg
The pink is one side with its two pins and the blue is the other side with its two pins.
Old 11-16-16, 02:34 PM
E
Thank you. that worked perfectly.
