Led equivalences, do they just make this up?
Old 11-16-16, 01:41 PM
E
Received 5 Upvotes on 5 Posts
So I went to the store today and saw a Philips brand MR16 LED on the shelf. The box said 50w replacement , 380lm. RIGHT NEXT TO THAT BOX was a Philips brand 50w MR16 bulb and if you turned it over on the back it said 730lm.
Old 11-16-16, 02:32 PM
Received 1,267 Upvotes on 1,207 Posts
I only look at the equivalencies to get started, I ultimately choose the bulb based on lumens (and temperature, but you didn't ask about that...).
Old 11-16-16, 02:59 PM
Handyone's Avatar
Just a guess, but I've had trouble in the past identifying which MR16 bulbs are low voltage or 120V.
The packaging might not make it clear.
Old 11-16-16, 03:04 PM
Received 3,983 Upvotes on 3,575 Posts
Exactly.... and some of the low voltage LED replacements have higher light output as they don't have a driver inside to overheat.
Old 11-17-16, 07:28 AM
G
MR16 can be purchased in specific light beam angles, ranging from 10 to 60. Several different angles are available.
10 is a very narrow spot, 60 is a wide flood.
50 watt 10 will have a higher lumen output than a 50 watt 60, because all the light in concentrated into the 10 angle.
If you want to push the light from the ground to the top of a two story house, use a narrow spot.
If you're backlighting a small tree, use a wide flood.
Another example is lighting art work. Different degree light beams can be used to light the artwork without lighting the surrounding area.
Most manufactures supply a chart showing the Photometric Data, which will show lumens at difference distances and beam spreads.
Look at the chart mid-way down this web page. You'll see the lumen output for different beam angles. Toward the bottom you'll see the Photometric Data charts.
