Lighting and switch
Old 11-16-16, 02:38 PM
D
Lighting and switch
The light has power and is on, with and without a switch wired to it. When I install a single pole switch it doesn't affect the light at all, very confused. Thank you for any help
Old 11-16-16, 02:58 PM
Received 4,116 Upvotes on 3,696 Posts
Welcome to the forums.
You haven't given us very much information to go on.
Is there a box in the wall for the switch to be put in ?
Was there a switch at one time that worked ?
What kind of light.... plug-in or permanent ceiling mount ?
Old 11-16-16, 05:37 PM
D
Sorry. This is new work I installed I have 3 outlets in a row then a closet light from the light I have a 12/2 into a new box. The closet light is a brand new led 2' strip and it is a ceiling mount. If the breaker is on the light is on, wiring it to a switch has not changed that. The single pole switch is also brand new but I have changed it to make sure the switch was not the issue. The problem is I can't figure out how to turn the light off without having to turn off the breaker.
Old 11-16-16, 06:00 PM
ray2047's Avatar
Sounds like you have a miswired switch loop.
Is this how you wired it?
