Second light fixture same switch
I have a new house built in 2016. I have a hall closet with no light. I want to extend light switch with hall light to create a closet light too so when hall light is on, closet is on too.
This is the next step up in my learning. I've never installed a box where the wires meet the fixture. I think that part should be easy.
I'm confused on the splitting of the wires for existing light switch. I have all the tools but what additional hardware should I buy like wires?
Does it matter if the wire is too small for load?
I know with electrical outlets, you have two types: the end of the chain and everything else. So with a light fixture, if it's daisy chained to another thing, will splitting it a third way be an issue?
How do you pick the right box to mount to stud for fixture? I've replaced fixtures before and made the old box work, but is there some kind of code on it that tells me the type needed?
Really, I want to say thank you for any help. I'm tired of doing stuff wrong even after my research and want to do this for my wife as a gift. So again ty!
In addition to Ray's comments, be aware of where you can locate a light fixture in a closet. It may not be an incandescent fixture (even if you plan on using CFL's, etc.) if it is within 12" vertically from combustibles (clothes hanging, etc.) Your best bet is to install a 12" mini fluorescent light with cover on the overhead wall above the door.
I, too would run a cable from a nearby receptacle to a switch and then to the light, allowing separate switching. How wide and deep is the closet?
This will be a lot easier if you can work in the attic.
Use the same cable as was there. A 15amp cable is #14, a 20amp cable is #12 and usually yellow.
The easiest way to do this is run a cable from the existing light to your new box.
Connect the white and black from your new cable to the existing white and black wires that feed the light fixture.
Wow ty all so far with replies. I'm so excited to do this.
I would add a new switch but thought I'd have to tear into drywall to make it happen? I have a guide thing I bought at Lowe's a few years ago that is supposed to help with guiding wires but never used it. It's on a spindle deal.
I called it stud but meant the beam. I remember some instructions saying to install it to the wood but I don't have to? That makes a lot of sense if I don't.
I have easy access in the attic to said area so I had planned on doing that. If it's not hard to do a switch, I may do that. Another option I thought is a fluorescent type light with an on off so it won't come on every time. I'll add pictures to show.
The closet is over 2 feet deep by a foot and a half wide. It's about 8-9 ft tall.
I'm showing looking into hallway with master on left and standing in master doorway looking at thermostat, switch and light.
A closet normally has a shelf 12" deep. You would not be able to install an incandescent fixture and meet the 12" clearance requirements. You might be able to install a fluorescent. Over the door sides like the best option.
I would recommend you purchase fiberglass glow-rods for fishing, they make the job much easier and you might have no problem running a switch or anything else.
