How can I fix my mistake with the ceiling fan?
Old 11-26-16, 02:03 PM
Using instructions on the internet, I tried to replace a 3 speed ceiling fan switch. To do this, I had to write down the colors of the 4 wires and their location (l, 1, 2,3). At my first attempt, it was turning at only 1 speed. I opened the cover and saw that 1 of the 4 wires was removed, I put it back successfully and everything worked fine at 3 different speed.
I was happy and then remembered that a few years ago, in my parent's apartment, the repairman fixed the same thing and at the end, he told me something like "sorry, I bought a 2 speed switch instead of 3, is it OK?", I replied yes. But after having replaced the switch myself, I thought that maybe he lied and the real reason was that 1 wire was disconnected.
I went to my parent's apartment, I first disconnected 2 black and white wires, then I could access the switch. I was looking for the 4 holes where the wires go, I saw wires in 3 holes but not on the 4th, I thought that was it because I noticed a black and white wire not connected. At this time, unfortunately, I completely forgot that they were the wires that I disconnected earlier (they probably power the light down). I then connected both wires but now, the fan doesn't turn at all! I noticed that I made a mistake. I also noticed that this switch is more completed than the one in my apartment because the holes with wires are on 2 levels.
What should I do to fix my mistake?
Attached are pictures of this Hunter fan.Name:  IMG_20161125_102918.jpg
Size:  26.0 KBName:  IMG_20161125_102843.jpg
Size:  25.4 KBName:  IMG_20161125_102830.jpg
Size:  22.1 KBName:  IMG_20161125_102816.jpg
Size:  34.2 KBName:  IMG_20161125_102810.jpg
Size:  43.1 KBName:  IMG_20161125_102204.jpg
Size:  23.7 KBName:  IMG_20161125_102147.jpg
Old 11-26-16, 03:10 PM
Received 1,020 Votes on 946 Posts
If you didn't take a picture of the wiring or write it down...... you're in trouble.
There are no published wiring diagrams or schematics for the pull chain wiring.
FYI.... there are dozens of pull chain switches. They ARE NOT interchangeable. When replacing a switch you MUST get the number off the old one and match it.
Old 11-26-16, 05:58 PM
E
Received 3 Votes on 3 Posts
1. Is it possible the pull chain in the off position?
2. Is it possible the reverse switch is in the center, not forward or reverse?
Old 11-26-16, 06:22 PM
I didn't change the configuration of the wires, it's just that I placed the 2 light wires in the switch, and maybe it broke the switch?
I don't think the pull chain is in the off position because I pulled it several times.
I don't think the reverse switch is in the center because I don't remember moving it, but maybe I forgot so I'll check it soon.
Old 11-27-16, 08:46 AM
E
It's possible one of the wires came loose.
Old 11-27-16, 11:58 AM
Trying2Help's Avatar
See if this will give you a hint on where it all went wrong....
Old 11-28-16, 07:26 AM
The switch is SANTA E70469. I want to pull out the wires from the switch and put them back according to the wiring diagram. It is very hard to pump them out and if I cut them, I leave wire inside. What should I do? Pull them harder?
Old 11-28-16, 10:48 AM
I finally used a nail to remove the wires and to put them in their new position, it is very convenient. I followed the wiring diagram you gave me and now, I have only 1 speed
. After I do the fan, I need to pull the chain 3 times to make it it run. The Santa e70469 switch has 8 holes instead of 4, I don't know why. From my search on the internet, it is still a 3 speed switch, so the repairman who installed it did not tell me the truth. What should I do now to have my 3 speed? Buy a new switch? If yes, which one?
Old 11-28-16, 04:20 PM
I only made sure that the 4 wires connected to the switch were the same as the diagram, I didn't verified the other parts of the diagram.
Old 11-30-16, 11:39 AM
Colors of wires aren't the only thing you need to verify. Don't know what the last person did, so you may need to check everything, to ensure it is wired correctly.
However, you might try swapping the two wires, for the speed you do have working and see if that corrects you issue.
You have one source, the switch just redirects the route it takes to get to the motor. Different route for each speed. Sounds like you may have the source connected to the wrong pin of the switch.
