Light only turns on when another light is on
Old 11-30-16, 09:21 AM
C
Hi there,
I have some outdoor lights that i can only turn on when another light in the house has been turned on. Is there anyway i can fix this?
thanks in advance,
CM
Old 11-30-16, 09:37 AM
G
Received 2 Votes on 2 Posts
Welcome to the forums.
Without more information, it sounds like someone pulled the feed for the outside lights from an existing switched circuit.
You will need to find the feed point and relocate it to a circuit which is not switched.
Old 11-30-16, 10:04 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
Need more info. Does it only turn on when a certain light is turned on. I agree it sounds like it was wires from a switched circuit.
Old 11-30-16, 11:47 AM
ray2047's Avatar
Received 15 Votes on 13 Posts
Open the box for the switch for the other light you need to turn on to get that light to work and tell us all the wires and connections.
Old 11-30-16, 01:50 PM
E
Received 3 Votes on 3 Posts
I usually call that a "master switch". Here's one possibility, I hope I can explain it.
14/2 hot wires run to several switches, it may also include some receptacles. At each switch box, there are three cables: two hot 14/2(power in, power out) and one switched 14/2 to the light.
When the box was spliced, the installer confused the 14/2 wires.
He/she tied a hot and a switch together. The remaining hot feeds the switch.
When this happens, everything down line is switched instead of being hot. The first switch would have to be ON for the second switch to work.
