Switching from light fixture to ceiling fan question
Old 12-27-16, 12:35 PM
T
I have an ugly light fixture in the corner of my room that is attached to the switch. In the attic the flat white wiring from the switch goes to an electrical outlet mounted in a plastic box in the attic. The light fixture is then supplies via wires (not plugged in) from the outlet box. The fixture is in the corner but I want the fan in the middle, so my question is, can I just cut the flat white wires supplying the outlet box and move it to the middle of the room to install a ceiling fan?Name:  White-Twin-Flat-Cable-Pure-Copper-Wire.jpg
Size:  26.7 KB this is the type of wire that's in attic that I want to cut
Old 12-27-16, 12:51 PM
Received 1,261 Upvotes on 1,203 Posts
Welcome to the forums. Might be best if you attached some pictures, I'm having a hard time following your description.
http://www.doityourself.com/forum/el...-pictures.html
