Installing a Lutron Maestro sensor in an old house - switched loop
Hi everybody,
I am trying to install this product in my kitchen for my ceiling light. Upon removing the switch, I saw 2 wires only; black and white.
I attached the green wire from the Lutron to the white wire from the wall (I read that this product, although it says that a ground is required, can work without a ground if you connect the green to the neutral). I attached the two black wires from the Lutron to the black wire from the wall. Both of the connections are attached with twist caps.
I went to turn on the power in the breaker and the lights will not turn on. However, I can hear "clicks" in the sensor so I guess that is working?
I've also learned that I may have a switched loop - in this case, is it not possible to use this Lutron?
Any help would be appreciated. Thank you!
The white wire by code should have been remarked black* to indicate it is a hot not a neutral. So basically the two black house wires go to the two black switch wires. The green wire is connected to the switch box if the switch box is grounded other wise the green wire is just capped and not used.
If the house is wired with BX the metal box may be grounded to some extent. If you have NM cable it isn't.
*The white could also have been marked or recolored red or any color but gray or green.
There are different versions of the Maestro. Also they are "type of light" dependent.
What model did you use ?
Ray, I will have to wait to tomorrow to try what you suggested.
Will the Lutron work if it doesn't have the trickle power from the neutral? (which I don't have in this case).
The trickle power would be from the ground. There is no neutral present there.
According to Lutron.... NOTE: Device will not function if it is not grounded.
