Need help remove vanity light fixture
Old 12-31-16, 09:12 AM
C
I need help to remove this vanity light fixture.
I have tried to (unsuccessfully) unscrew the orbs between the light posts
I am able to unscrew the orbs above each light socket, but it only reveals wires and does not provide a clear path for removing the fixture.
any advice / instruction is appreciated. I no-longer have the original fixture name/manufacturer information. Thank you!
Images of fixture:
https://i.imgur.com/tUSKNsc.jpg
https://i.imgur.com/o0zFMdl.jpg
https://i.imgur.com/FB7kNMu.jpg
Old 12-31-16, 09:49 AM
P
Received 2,185 Upvotes on 1,955 Posts
Remove the two decorative nuts (orbs). You may need to use pliers. Once they are removed the face of the fixture will come free from it's base which is attached to the wall.
Old 01-01-17, 10:09 AM
W
Received 63 Upvotes on 55 Posts
Fixture
Remove the base to reveal the wiring connections.
