ceiling fan light fixture not turning on/off
Old 01-08-17, 10:07 AM
Cool ceiling fan light fixture not turning on/off
I have a Hampton Bay ceiling fan with light. It has a wall switch with 4 fan control buttons, low, medium, high and off and one light switch on/off button. There is also an on/off toggle switch for the entire switch.
A few days ago the on/off switch stopped working fan and light. I finally looked at it. I pulled the battery out and put it back in. After I did that I noticed the on/off switch for the entire switch and turned it off and back on again. The light on the fan went on.
Problem is the button that should turn the light on and off still doesn't work. I can only turn the entire switch on/off not just the light.
Any ideas on how to fix this problem?Name:  20170108_130007.jpg
Size:  19.1 KB Name:  20170108_125955.jpg
Size:  24.7 KB Name:  20170108_130021.jpg
Size:  22.5 KBName:  20170108_130021.jpg
Old 01-08-17, 10:17 AM
ray2047's Avatar
If the wiring hasn't been touched and it worked before you may need a new switch.
Old 01-08-17, 10:19 AM
darn I was hoping there was something I could do to fix it.
