What kind of lights would you use in this bookcase built-in?
Old 01-28-17, 06:28 PM
R
I decided to add some lighting in builtin. Not sure if I will put lights at the top only or also under the other shelves. From what I am seeing, the puck lights aren't meant to be hardwired to a wall switch like regular lights.
So what would be the best way to do this? The wall is completely open with no drywall up.
The built-in is the book shelf next to the door.
Old 01-28-17, 06:46 PM
ray2047's Avatar
12v LED tape lights might work well.
Old 01-28-17, 06:53 PM
R
I was hoping to have something more permanent that was wired through a wall switch. Even if the lights are only at the top of the built-in.
Old 01-28-17, 06:54 PM
Received 3,887 Upvotes on 3,484 Posts
Any more detailed drawing ?
LED tape is good but not on moveable shelves.
Light just at the top.... in the bookcase.... is pretty ineffective.
I have two similar looking bookcases in my living room lit by a recessed eyeball over each one.
Old 01-28-17, 07:07 PM
R
Maybe you are right, It may be ineffective. I already have recessed lights and I will be adding sconces this weekend. My idea is to create contrast/shadows more than functional light. I have better sketchup angles or actual pictures of the area I'd be glad to post. What are you looking for?
