adding recessed lights to ceiling fan switch
I have a ceiling fan that uses a remote to individually turn the fan and lights on and off. Can i add 2 recessed lights to the same circuit/wall switch?
If your fan uses a remote control you can not add additional, external lights. All the switching is going on inside the fan so there are no wires or output to control additional lights.
i meant can i use the wall switch for the ceiling fan and recessed lights. for instance i can turn the recessed lights and ceiling fan on from the wall switch then turn the ceiling fan/light off from its remote.
black on the the other side of the switch runs to the fan
Better in my opinion is to replace the single switch for the fan with a duplex switch and run the cable for the new light to the switch box, That way fan and new lights will be on separate switches,
