Advise for Lanai lighting
Old 02-27-17, 12:01 PM
O
Received 6 Upvotes on 2 Posts
I'm looking for some thoughts on adding outdoor lighting for my lanai screened-in walls. I'm thinking of a product such as LED strips, 12volts, dimmable if possible. Ideally, the strip would have a 2-way tape adhesive back so I can apply it to the top plate of the wall all the way around. The total linear length is 81 ft. I can add transformer(s) just about anywhere along its length.
My only issue is how well the adhesion would be in a hot/humid Florida summer climate.
A product suggestion would be great. My only search has been on Amazon so far.
Thanks
B
Old 02-27-17, 05:09 PM
Received 3,420 Upvotes on 3,066 Posts
I've used the CB Concept strips in several places including under my patio. I don't recommend a self stick product that will stick in humid weather. I've only used screw type mounting clips. Fairly easy to install them.
In the link is the 100' product that you can cut down to your own custom length.
Comes in several different whites from warm white to cool white to a very white light.
amazon/LED/outdoor strip
