Light Problem
Old 03-05-17, 02:38 PM
Light Problem
Hi guys
i have a problem whit the light, when i press the bottom on the light gone hi intensity and he go off slowly. Do you have idea? Thank you
Old 03-05-17, 03:06 PM
czizzi's Avatar
Some ceiling fans have built in regulators that monitor the output to the lights to meet energy savings guide lines. I have run into units that function perfectly other than the module that controls the lights has gone bad. Replacement of the fan was the result or if you can find a new light kit, that will resolve your problem. Unfortunately, items are discontinued and replacements can not be found in some circumstances.
Old 03-05-17, 03:35 PM
ray2047's Avatar
Original post separated from unrelated thread by a different member..
Old 03-05-17, 03:37 PM
ray2047's Avatar
Welcome to the forum.
Do you mean pressing the switch for the light? Is this a lamp? Is this maybe a lamp with an inductive touch switch instead of a mechanical switch?
Pleaee add your location to your profile.
