Capping old wires
Old 03-18-17, 12:44 PM
K
Capping old wires
I'm updating some light cabling such that I am going from two 3-way switches to one single pole switch.
After its complete I will be left with a dead cable. Both ends of the cable will be in a 3 gang electrical box. Do I need to cap each wire off separately with a wire connector or can I use a single wire connector for all 4 wires (red, black, white, ground). I live in MN if it makes a difference as far as code goes.
Thank you.
Old 03-18-17, 12:49 PM
Received 3,884 Upvotes on 3,481 Posts
You don't need to cap the ground but all the grounds stay connected in the box.
You can cap the other three together at both ends and that will signify that the cable is not in use.
Old 03-18-17, 01:41 PM
K
<removing post as it was incorrect>
Old 03-18-17, 01:56 PM
K
Right now the ground wires at one end (where I am removing the switch) is just going into the existing 3-way switch. Are you saying I should put that ground into the existing set of ground wires which is on a different circuit? That seems a bit strange to me as that would give the ground a path to the other electrical box. So I'm just double checking I understand.
Old 03-18-17, 01:58 PM
Yes.... the grounds in an electrical box are connected together.... even though there may be several circuits in it.
Neutrals are kept separate.
