Can Lights on three-way switch question
Old 03-22-17, 12:55 AM
U
Here's what I am trying to do in my basement: Power source to First can light, to second light, 3rd, etc. Then to a three-way switch; and then to the other switch. I want to use this setup in order to utilize the existing circuit without using junction boxes.
I thought I kind of understood what to do: 14/2 wire to first light; then 14/3 between lights; then 14/2 to first switch; 14/3 to second switch. If this is right, how do the connections look between lights? The can lights have quick connects for ground, white, and black. Should the red wires just be quick connected with the black wires?
Old 03-22-17, 01:39 AM
Received 3,611 Upvotes on 3,237 Posts
Welcome to the forums.
You are creating a switch loop at the end of the circuit. Technically this is not to code as you are required to have a neutral at least at one switch location. You could use a three wire cable from the last light to the first switch. That would bring neutral to the first switch where it would be just capped off unless needed.
The lights would connect to the red and white wires. The blacks are carried thru.
Old 03-22-17, 01:51 AM
ray2047's Avatar
Simplest is to bring power to the switch first but what you want to do is doable.
At the first light:
  • Black of power in 2-conductor cable to black of power out 3-conductor cable
  • White of power in 2-conductor cable to white of power out 3-conductor cable and white of the light.
  • Red of three conductor cable to black of light.
  • At each of the other lights red to light black.
  • Black in to black out.
  • White in to light white and white out.
At the last light run a 3-conductor cable to the first 3-way switch.
  • Red in to red out and black of the light.
  • Black in to black out to switch.
  • White to white out and light white.
This gives you the code required neutral at the switch. The black for constant power to the 3-way switches and red to carry switched power back to the lights. To meet code you will probably need a 4-conductor cable (red, black, blue, white) between the switches.
Here is how the switches are wired:
Location of common terminal may be different on your switches.
Darn, Pete types faster.
Old 03-29-17, 03:58 PM
U
Thanks and a follow-up
Sorry for not responding sooner. I had some trouble logging in and just gave up after a while. I really appreciate your responses. I was not aware of the neutral wire in the switch box requirement. Having considered everything I am trying a new approach:
I just have enough existing wire to reach one switch location, so I will run source --> First Switch --> Second Switch --> to the lights (14/2, then 14/3, then 14/2).
However, I also want to run two additional set of three-ways off this circuit, along with an outlet. Is this doable? The attached image reflects what I am thinking; not sure about how to get power to the other switches and outlet.
Old 03-29-17, 04:10 PM
U
Well that picture didn't turn out like I had planned
Old 03-29-17, 04:48 PM
ray2047's Avatar
You didn't crop it and it appears to be too small to enlarge well after cropping.. Draw your images within a 600 pixel with and a height of 1500px you should be okay.
Old 03-29-17, 06:46 PM
U
Let's try this again.
Switches 2 3 and 4 intended to be in the same box. I think I know what to do with 4. Just need some help with the wiring on 2 and 3.
Name:  2017-03-29 21.44.48.jpg
Old 03-31-17, 09:48 AM
U
I'm pretty sure I can't do what I've proposed. I will sketch up a revision later on.
Old 03-31-17, 10:39 AM
You are correct. Since power comes in at switch 1..... there is no always hot at the 2,3,4 location.
You also show many cables above switch 2 coming to that box. Those may be just devices powered off the same circuit but plan your wiring to keep cable count as low as possible.
Old 03-31-17, 09:03 PM
U
Update. Here's what I am thinking; need some help with the connections between 1 and 2 and the other 4 wires on the left. C marks the common terminal and orange is used for white wires.
Good point on the number of wires. I need to calculate the capacity. If needed I can move something around.
The wiring from switch 1 to the stairway light and to the other switch for that light are behind drywall as the stairway was finished by the builder. Same goes for the wiring to the outlet.
