Exterior light fixture problem
Old 05-20-17, 08:57 PM
Hi I have an external light fixture by my garage with three candelabra bulbs. When I bought the house, it had 3 regular bulbs rated at 60W. I switched to three led bulbs that are 60W equivalents. This worked fine for all of last year.
This week I noticed all three bulbs are very dim. I tightened one and the other two became even dimmer. Loosening it, they brightened up again.
One other bulb, I tightened and then loosed and now it doesn't work anymore. I tried another bulb in its spot and it doesn't work at all.
Lastly, I got an incandescent bulb and tried it in one spot (first one above). Upon tightening , the line remaining 3rd bulb completely went out.
What is going on? Seems like a wiring issue ?
Thanks.
Old 05-20-17, 10:26 PM
ray2047's Avatar
Is there a timer or photocell on the light? If not is it a regular switch?
Old 05-21-17, 05:44 AM
Yes actually there is an old Intermatic timer that controls it.
Old 05-21-17, 07:31 AM
ray2047's Avatar
Unless the timer has a neutral it probably isn't compatible with LEDs. You could try bypassing it and see how things work out.
Old 05-21-17, 08:49 AM
Hmmm but it worked all of last year though. Actually based on your advice I tried to manually turn on the fixture using the timer and all three bulbs worked. I'll report back at 6pm when the timer is set to go on. Thanks.
Old 05-21-17, 10:03 AM
Also i should mention that the same fixture and same bulbs and timer are at the front door and have been working without a problem. Not sure what is causing this other one at the garage to fail.
Old 05-21-17, 12:03 PM
ray2047's Avatar
As a test swap the timers. If the problem moves with the timer then you know the timer is the problem.
