Low voltage plug
Old 06-07-17, 01:40 PM
jjrbus's Avatar
Received 2 Upvotes on 2 Posts
Low voltage plug
The male part of this plug is bad, it is for an inside LED decorative tree. I have searched the web looking for a replacement and not finding anything.
Anyone know the name or where to look?
It is for a 120V to 24V ac wall wart.
Old 06-07-17, 05:30 PM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
Since it is low voltage I would just bypass the plug (cut it off) and direct wire it to the wall wart. Or get a new 24 volt wall wart with wire leads and splice the tree wires to them.
Old 06-07-17, 06:01 PM
jjrbus's Avatar
Thanks for the response, greatly appreciated. I'm confused on this, I would have no issue direct wiring it, but the wall wart is one piece and I see no way to open it or attach wires to it, other than a plug?
Old 06-07-17, 06:05 PM
ray2047's Avatar
Then you may need a new wall wart. Me, I'd probably cut the prongs off the plug and solder them to the wires then just push them into the power supply. I might even carefully "disassemble" the plug with a hammer to get better access to the prongs.
Old 06-07-17, 10:04 PM
Received 3,422 Upvotes on 3,068 Posts
That's called a DIN speaker plug. Used on mostly European audio equipment sold here.
I left you a search page. You may be able to find a US based retailer.
google/search=din+speaker+connector
Old 06-08-17, 04:18 AM
jjrbus's Avatar
AH HA! DIN speaker plug. Just what I needed. Found them on Ebay mostly from Europe, Australia Hong Kong. About $5 ea with shipping.
There is an electronics place in Orlando that has bins of odd and surplus stuff, I have been waiting for an excuse to go to Orlando to see if they had anything.
I will give disassembling the old plug and soldering before I order a try. Not sure if I should use a framing hammer, ball peen or a stonemasons may be the right tool for this job
Thanks for the input greatly appreciated. Jim
Old 06-08-17, 07:57 AM
jjrbus's Avatar
Maybe you have noticed that electrical/electronics are not my strong point. I managed to get the plug apart for soldering but there is no way to identify which wire is + or- in the plug.
The wart itself is not polarized, both prongs are the same size, not a large and small one, going into the 120 receptical. So I would guess that polarity is not important? Yes no??
Not even sure I am asking the question right? Jim
Old 06-08-17, 12:55 PM
ray2047's Avatar
If it is AC it doesn't matter. Test the wall wart with an analog multimeter set to DC. Positive probe to one slot. Negative probe to the other. If the needle tries to go backward you have the positive probe in the wrong slot. Not sure how a digital indicates reverse polarity but you could test a battery to see.
Old 06-08-17, 02:40 PM
A digital meter puts a - before the value.
