Recess wiring
Old 07-11-17, 05:02 PM
B
Recess wiring
http://imgur.com/a/s2S0
Heres the situation. I have placed a 6inch recess in the attic. Below are dual 3ways fed by 2 12/2 and 2 12/3. The diagram shows their wiring. All connections seem good.
Above in attic are two junction boxes.
Lefthand has 1 set of 12/3. Righthand 1 set of 12/2.
The righthand white turns on light when paired with black and white directly.
The lefthand white does not.
I attached.the red wire from lefthand junction 14/3 to the black wire on light.
Cannot get any sign of life from switches.
Only get constant on with light when direct loading it.
Old 07-11-17, 05:07 PM
Tolyn Ironhand's Avatar
Received 672 Upvotes on 570 Posts
Welcome to the forums!
Sorry, but your link does not work for me.
Old 07-11-17, 05:32 PM
B
Sorry try this
This should work better.
Old 07-11-17, 05:41 PM
ray2047's Avatar
Imgur is not a good way to add images. Brings in a bunch of SPAM even if you get it to work. http://www.doityourself.com/forum/li...rt-images.html
Old 07-11-17, 06:54 PM
B
Old 07-11-17, 06:55 PM
Received 3,415 Upvotes on 3,063 Posts
I imported your pictures but don't fully understand them.
Looks like 2) three way switches with the common not identified.
In the second picture.... the fixtures are in series. You need to connect the white from each fixture to the white of the three wire cable and black from each fixture to the black wire. Red will be capped off and unused.
OR... is picture two a switch loop?
I labeled your picture for discussion clarity.
